As you can see from the above sample you can model your shift work requirement when work hours are known in advance without need of multiple teams on a single activity by splitting the activity into separate activities. For the modeling of shift work when work is not known in advance P6 will fall short.
As long as your modeling requirement for shift work is that simple, work hours known in advance, I recommend you try modeling shifts as separate activities as shown. You shall create a hammock to mimic the single activity. It shall do the trick.
Because in this example no resource works on the same shift there will be no concurrency. The project might or might not be delayed by the absence of any given resources depending on whether a previous delay opened or not some resource float. For example if I work on the third shift and do not come to work on the first day the job will be delayed by 3 shifts, this will open float for those on the 2nd and 1st shift. Can we argue that if not by my absence the worker on the second shift if absent shall bear some responsibility? Distribution of responsibility is not an easy task.
21 years 8 months
Member for21 years8 months
Submitted by Rafael Davila on Wed, 2011-02-09 05:45
In addition to supporting documents like time cards and the worksheet an impact analysis might look like this:
I believe the worksheet shall be enough to prove delay on activity while the CPM is necessary to show delay on project duration. Anyway delay on project activity without delay in overall job duration is still a Disruption, the difference on the relative cost of each can be substantial.
If resources work on different shifts as not to interfere with each other then set them to work on different teams with different work hours. Note each resource will work a total of 20 work hours but can be set to different hours. Even with same work hours the results will differ substantially. Instead of a 2 days impact will be a single day impact. Make sure you have software capable of true modeling of shifts. Beware of add-ins that pretend to mimic teams and productivity.
You can model your activity to be performed by several resources working on different shifts untill all resources produce a total work volume on a first come first serve basis or you can model a fixed portion of the total volume of work to be performed by each resource and the activity will last from first resource hour to last resource hour. Similar but different scenarios.
You are asking for the scenario where you know in advance how much work will be done by each shift, perhaps a simple scenario most software shall be able to deal with. Here modeling each shift as a separate activity can do the trick, otherwise if not known in advance how much work will be done by each shift most software falls short. With Spider you can correctly model both.
21 years 8 months
Submitted by Rafael Davila on Tue, 2011-02-08 15:56
Do not forget to address issues on concurrency; two or more resources might be delaying an activity at the same time, in such case you got a shared delay responsibility.
As you pointed out it is not only about teams working on the same activity a functionality that also allows you to model true shift work, it is not only about productivity it is also about volumes of work. It is how everything works in harmony.
Without volume of work it is very, very very very hard and cumbersome to define productivity. That is why many CPM software developers have not yet figured it out without the need to re-program all. They are using hour as the measure of work, a concept used for time studies but not a good choice for CPM schedules.
It is easier and more intuitive to say a productivity of 10 cm/hr or a productivity of 20 cm/hr than 50% productivity of a standard production rate. Can you imagine productivity 50% meaning 50% of a standarized production rate, but which? 20 cm/hr? 10 cm/hr? Why not 25, or maybe 26, or maybe 54, or maybe .....
I am not sure people using software that use hour as the work measure will be able to even get it, otherwise they would be using other software like Spider.
14 years 9 months
Member for14 years9 months
Submitted by lord_horn_asstr on Mon, 2011-02-07 09:22
this task is for Spider Project. It simulates independent resource work and produce necessary reports.
But yes, the task you described is too simplistic. Actually if resource X missed 10 days and Y missed 3 days then resource Y will do additional work if to compare with planned. In Spider Project you will get a report on planned and actual work and time for each resource and an activity.
If both resources have the same productivity and planned activity duration is 20 days then in your case activity duration will become 26.5 days as shown in the picture below. Such situations may be not only actual but also planned - assigned resources may have different calendars.
21 years 8 monthsAs you can see from the above
21 years 8 monthsIn addition to supporting
21 years 8 monthsDo not forget to address
For this you got to model idle resources.
19 years 10 monthsHi Vladimir I suppose the
Hi Vladimir
I suppose the simple answer is because I can.
I am currently the only moderator operating on Planning Planet so I make judgements as and when necessary.
Mike T.
21 years 8 monthsVladimir,As you pointed out
Vladimir,
14 years 9 monthsThank you all.Regards,L_H
Thank you all.
L_H
24 years 9 monthsHi Mike, why did you decide
Hi Mike,
why did you decide that this topic is on claims?
It is necessary to plan resource usage and to control resource performance not only in conflict situations.
Vladimir
24 years 9 monthsHi Lord, this task is for
Hi Lord,
Vladimir
19 years 10 monthsDear Lord First of all
Dear Lord
First of all welcome to Planning Planet.
If your software allows it the simplest method is to set up two new callendars - one each for resource A and B.
Set the 10 non work days on Resource A calendar and the 3 non work days on resource B. Reschedule and your task will change asccordingly.
Retain the normal work calendar on the task.
In general it is not good practice to have different calendars on resources but it works for specific occasions such as your scenario.
PS I have moved your thread to the Claims topic.
14 years 9 monthsSorry, For point 4 above, it
Sorry,
For point 4 above, it should say:
30 days + 10 days delay due to Resource X + 3 days delay due to Resource Y (a simplistic example)
THanks you
