Basically, consultant find it hard to approve a submitted plan in the event that they are not in control of future events.
IN this situation, if you keep using the submitted and unapproved plan, periodic update, tools in monitoring your construciton activities, then, there is a big chance that said submitted and unapproved plan may become approve and baseline programme for which you are monitoring your construction activities.
The submitted and unapproved plan may also be the tools that will be used someday in your claim for extension of time.
Charlie
17 years 3 months
Member for17 years3 months
Submitted by Samer Zawaydeh on Fri, 2008-10-24 08:28
If you have a Contract signed under the general clauses of FIDIC then if the Engineer did not reply with 21 days of submitting the program, then the Contractor has the right to proceed with the Execution of the works as per submitted program.
If you Contract is not under FIDIC, and it only states the start and end date of the Contract, then you can proceed with the Construction as per you deem fit.
unsolicited advice: You cannot take it as approved (unless there is approval), but you can always proceed (if you got NTP). You can always keep the record and count the number of period elapsed until you got your Plan approval (i believe your client is sharing the risks).
23 years
Member for23 years
Submitted by Hemanth Kumar on Fri, 2008-10-24 06:20
Please check the Contract documents for any information in them regarding you questions.
In the event, that no official instructions are sent (seems that your clients management is weak or afraid from consequences) then you need to check all information at site. Please review the Minutes of Meeting and Site Memos from all sides to support your arguments.
17 years 3 monthsRE: Time Limit For Time Plan Approval
Dear Kumar,
What are you going to do for the remaining part of the Contract?
How much work is remaining on the Contract? You will need to agree on a process to complete the works.
Best,
Samer
20 years 10 monthsRE: Time Limit For Time Plan Approval
So what, if any, dates did that state?
23 yearsRE: Time Limit For Time Plan Approval
Yes There Was
Hemanth,
6 months ago - was there a contract in place to do the works or were the discussions prior to any contract being formed?
Thanks Mate
20 years 4 monthsRE: Time Limit For Time Plan Approval
H,
Charlie
Dear H.
Good luck,
Samer
19 years 1 monthRE: Time Limit For Time Plan Approval
Q1 : Can a submitted plan can be taken as approved if no reply is given within a certain period ( Nothing mentioned in the contract )
Nothing Mentioned In the Contarct About Approval time
Dear Kumar,
Good luck,
Samer
19 years 10 monthsRE: Time Limit For Time Plan Approval
Hi Kumar
You seem to have got yourself into a "denial of access" situation.
As always - "Depending upon what it says in your contract" - you are normally told the start date of your works.
Access would usually be available on the same date as your contract start date.
If you are denied access then you have a relevant event for an extension of time.
Please let me know if your circumstances are different.
