How to Check the Contractor Stability
18 years 6 months
Sam,
I suggest,in addition to what have been posted, you visit their similar projects (completed & in-progress) and talk to their client. From that you have the feeling who the contractor is.
Hernan
18 years 5 months
In one of my previous firms, we use to evaluate our contractors on the basis of grade points. We have developed a questionnaire of 20 questions related with our projects and we used to scale them between 1 to 4 points.
Then depending upon the weigtage, we use to multiply the imporant questions like experience, available resources, client list, etc. with 3 0r 4 and for the least important questions multiply by 1.
Thats a 100 mark gradation system.
Thats how all the above points like financial stability, experience, resources and other points were considered.
Thanx
Raviraj
24 years 4 months
I think I would ask why you were asked to do this in the first place!
You are supposed to be a Planner not a procurement expert, assist in the process yes, but not lead it!
19 years 7 months
Hi Samuel,
As far as i know there is no standard for this evaluation, each employer has his own standards.
U can make a comparison sheet that u can submit to the management in order to aid them deciding.
18 years 5 months
Thanks karim,
I was facing also a small problem, which is after setting all the criteria items including your valuable suggestions, How to weigh such items, I mean, I believe there should some marks depending on how important this item is, like for example 15% for carrying out similar projects, 10% for possession of equipments, and so on.
How to evaluate each of those items, s there any standards for such evaluation?
19 years 7 months
Some documents which u can ask from the contractors in addition to your list in the tender can be as follows:
1- Financial Situation: the contractor should list his total assets and liabilities for previous years.
2- Summary of current contract commitments: the contractor should list the value of the outstanding works in addition to the forecast completion dates.
3- Construction Experience: the contractor should list the name s and total values of his previous construction experience.
HTH
Karim
