1 day duration tasks
15 years 4 months
Thanks Mike.
19 years 11 months
Hi Vasilios
There should be an Icon box that allows you to set your snap period.
You should also check Tools > Options > Progress and set the snapping unit to the same category.
Also got to Library Explorer and Time Units - here you can tick whatever time units you want to display in the Snap Dropdown.
15 years 4 months
Hi Mike,
Where can you find what your snapping unit is set to?
Kind Regards,
Vas
19 years 11 months
Hi Craig
What is your snapping unit set to?
If it is set to Days then the duration will snap to the next day.
If it is hours then it will snap to the next hour.
If you have - say - an 8 hr work pattern but your 1 day work period is 7 hrs then the next task will start late in the afternoon of the same day.
Set your date format to show time as well as dates and you can see where things come adrift.
Having set your work pattern in the calendar make sure that the default setting (tools > default) is the same period.
