Reinstall Excel 2003. you can retain both excel 2003 and 2007 on the same OS. Use 2003 for export-import and 2007 for the rest. I find MS Excel 2007 much superior to its predecessors. Alternatively, consider using Open Office (freeware) for dbf/wk1 formats.
20 years 3 months
Member for20 years3 months
Submitted by Hannes de Bruyne on Thu, 2008-08-07 03:48
Another problem is that excel 2007 is not allowing to save the files as wk1 or dbf. So that exporting/importing with excel 2007 seems impossible. Do have any idea for this?
22 years 9 monthsRE: RA Excel Files Help ???
20 years 3 monthsRE: RA Excel Files Help ???
open dbf in access copy to excel, than back to access and save as dbf.
Hannes
Hello all,
as a matter of fact, one should not use MS Office 2007, except if MSO is the only application software on the computer;
MSO 2007 is denying any working possibility to any other apps on the pc
MSO 2007 is 110% proprietary, it is not even possible to save files under an older MS file format!
ergo, do not use MSO 2007
Alexandre
18 years 9 monthsRE: RA Excel Files Help ???
same reason - excel 2007 doesnt support excel older than 1997-2003
21 yearsRE: RA Excel Files Help ???
Hi There,
Hi There,
Are you serious? I mean going back to excel 2003? If it is the only solution OK. But what is causing this. Have any idea?
ya that is the only way , go back to excel 2003
Hi all,
switch back to MS Excel Xp or 2003!
Alexandre
17 years 4 monthsRE: RA Excel Files Help ???
hi mr. david
ive got a problem same as yours, if u found d solution could u share it to me...tnx..
regards
By the way Operating System is Windows XP Professional on my desktop.
