Primavera Project Planner - P3 Member for 19 years 11 months Member for 19 years 11 months Submitted by vito Kooij, van on Mon, 2006-04-24 10:31 Permalink RE: PROJ environment variable is too long or use 8.3 name/adress Member for 24 years 7 months Member for 24 years 7 months Submitted by Paul Harris on Tue, 2006-04-18 08:30 Permalink RE: PROJ environment variable is too long Another solution is to map a network drive to the location that you files are stored in. Paul E Harris Eastwood Harris Pty Ltd, Melbourne, Australia Planning and Scheduling Training Manual & Book Publishers & Consulting www.eh.com.au Member for 22 years 4 months Member for 22 years 4 months Submitted by Jorge Taguinod on Tue, 2006-04-18 07:47 Permalink RE: PROJ environment variable is too long Hi! This happens when you store your project files in a deep directory (consisting of multiple levels of subdirectories). Simply transfer your project files (about 23 in all) to a directory consisting of only a few levels. E.g. C:\P3WIN\PROJECTS This should work. Best, Jorge Member for 19 years 6 months Member for 19 years 7 months Submitted by Peter Raybould on Tue, 2006-04-18 06:03 Permalink RE: PROJ environment variable is too long The file path is to long, you need to reduce the path to the project. Log in or register to post comments
19 years 11 monthsRE: PROJ environment variable is too long
24 years 7 monthsRE: PROJ environment variable is too long
Paul E Harris
www.eh.com.au
22 years 4 monthsRE: PROJ environment variable is too long
Hi!
This should work.
Best,
Jorge
19 years 6 monthsRE: PROJ environment variable is too long
