Budgeted resources changes everytime i import data
21 years 2 months
Hi Rolyn Transfer Autocost Rule from another Project. (One you are sure that you did not have any problems with)
Also have a look as to earned Value are you using Target Project or Current Project
21 years 5 months
Alex,
the budgeted quantity of some of my activities changes, some have increased and some decreases... there’s no pattern whatsoever. therefore my budgeted cost also changes. This is the first time I’ve encountered such problem like this. and this problem only occurs every time I import data (i.e. AS, AF & PCT).
24 years 6 months
Rolyn,
I would check your autocost rules (Tools, Optiosn, Autocost).
You mentioned it is cost loaded and you collect AS, AF and PCT. To have the system estimate the actual you will need to have the option checked to Use updated percentage against budget to estimate actual cost (or quantity) to date.
If these are not set and you are not collecting and inputting/importing the actual cost (or quantity) then as you import the AF the RD becomes 0 and forces the CTC and CAC (and QTC/QAC) to zero and you appear to lose those values from the Project.
HTH
22 years 9 months
Can you please describe a bit more
is your quantity or $ changed
is increase or decrease
how you update your actuals (Import and Export)
cheers
Alex
