A Baseline Critical Path can have float! best way to show it?
12 years 6 months
Thank you for the comments, you guys are great!
21 years 8 months
Early Completion Schedules
Ghost Schedule
At home we do not use the NEC and Early Completion Baselines are prohibited to the extent if you submit an Early Completion Schedule it is interpreted as a reduction in contract duration. Therefore we submit a schedule that uses all contract time and keep a Ghost Schedule we call it our optimistic schedule.
Late Completion Schedule
I recall a case where we submitted a Late Completion Schedule on the basis that for a critical delivery the Brand Name Specification material delivery was preventing the schedule from finish within contract date. Prior to bidding the supplier provided his quotation but was reluctant to provide a delivery schedule.
21 years 8 months
Contractors’ float in ECC programmes
Terminal float: Under NEC 3 contracts the period between planned completion and completion date is owned by the contractor under the contract. NEC 3 requires all submitted schedules to show reasonable terminal float and any schedule lacking terminal float might be rejected as targeting for a schedule with no terminal float is considered bad practice as this means close to 50% of the time you will not make it.
You can show terminal float as a hammock while showing float based on Planned Completion Milestones as shown in this sample schedule.
  1. Fix Contract Completion Milestone using start and finish constraints equal to the contract completion date and set it to not consider in scheduling. Do not fix this milestone using activity links.
  2. Apply contract finish date to Planned Completion Milestone.
As a user of Spider Project I mostly look for float calculation that do not tweak the late dates but also have access to negative float values calculated by such tweak as a separate field.
terminal-float-01
terminal-float-02
click thumbnails
However if using the software resource leveling most software longest path and float calculations will be unreliable.
Good Luck
16 years 3 months
in p6 your can define the number of days that you want to be critical if you float is 5 days just set it to 5 days or less. You can set the critical path be to be the longest path.
One thing that I do is create a activity code called CP then I filter for the last activity can then I look at the predcessor window and I look for the predcessor that is both driving and critical and highlight it and then I select goto and then this activity is added to the view I keep doing this until i get back to the data date then I assign all of those activities the CP code. now i can filter for the CP activity code and I have the true critical path,
