Resource Loading
17 years 1 month
16 years 3 months
possible 2 solutions
problem#1 you do not have the proper rights to import resources
solution get the proper rights
problem #2 your setting option when importing is set to do not import
solution during the import process when you get to Update Project Options select modfiy
in the second section under Data type: Global in the action column cahneg al lof the setting to Insert NEW
8 years 2 months
Chris,
On the XER Import, check the Update Project Options to see what settings are being applied when you import the xer file.
Available Options are:
  • Do Not Import
  • Insert New
  • Keep Existing
  • Update Existing
It may be that this is set to Do Not Import for the Resources.
Steven
