It looks as if the problem I am having is a result of filtering out the tasks. It is a five-phase project, and I am populating just one phase.
All of the tasks have a Phase reference in a customised text field, but I noticed when expanding each task that the resource allocations do not, so simply by pasting the phase reference against all of the resources on the task usage view, the problem is solved.
Again, many thanks for taking the time to help - very much appreciated.
It seems your installation may require repair. Outline-"Show all subtasks" works fine for me as it does for Alexandre - using both MSP 2010 and MSP 2016. That is, clicking the command in the Task Usage view opens all tasks to view all tasks and their resource assignments. You can also select multiple tasks and use the outline "Show/Hide Subtasks" command to roll the assignments in or out. Good luck, tom
22 years 11 months
Member for23 years
Submitted by Tony McClennon on Fri, 2020-05-15 09:54
Thanks for replying. I can use the "Outline-Show All Subtasks" or "Level X" options to show all the tasks without any problem.
However, if I want to show each of the resources allocated to the tasks below the task name (as per line 213 in the extract above), the only way I can do this is by clicking on the expand arrow against each task (rather like opening out a summary bar).
Unfortunately this is extremely time consuming, and most of the time I am trying to do this, I manage to click outside of the expand arrow and all the resource rows are then hidden again.
Should have mentioned that I am using Project Professional 2016.
Since posting, I have been doing a bit more searching and on previous versions of MS Project, you could apparerently achieve this by using Resource Allocation via an option on the "outline" icon, but which seems to have been removed in MSP 2013/6.
22 years 9 months
Member for22 years10 months
Submitted by Alexandre Faul… on Fri, 2020-05-15 09:28
if you mean that you want to show the detail of one specific task, I suggest that you display the gantt chart in the upper pane of the screen, and the task usage view in the lower pane
then, navigate from task to task in the gantt chart and you will see the detail of the resource assignemnts in the task usage view, exactly the way you describe in your post
Alexandre
22 years 9 months
Submitted by Alexandre Faul… on Thu, 2020-05-14 19:14
I do not understand where your problemn stands; I have tried on one of my sample projects, "Outline-Show All subtasks", or "Level x" works perfectly in Task Usage
22 years 11 monthsTom/Alex,Thank you for your
Tom/Alex,
Thank you for your replies.
18 years 11 monthsTony,It seems your
Tony,
22 years 11 monthsHi Alex,Thanks for replying.
Hi Alex,
22 years 9 monthsTony,if you mean that you
Tony,
Alexandre
22 years 9 monthsHello Tony,I do not
Hello Tony,
Alexandre
