Planning, Scheduling & Programming Discussion Member for 17 years 9 months Member for 17 years 9 months Submitted by Mohammad Mojah… on Wed, 2011-11-02 08:53 Permalink Dear Plz find activities Dear Plz find activities for Mosque Activity ID Activity Name Mosque ( B - 040 ) (Z7) Mosque ( 7-B040-1 ) Site Work Z7B040-1-0010 Excavate for raft foundation Z7B040-1-0020 Drill Probe hole Z7B040-1-0030 Grout Probe hole Z7B040-1-0040 50 mm thick blinding concrete raft foundation Z7B040-1-0050 Raft foundation Z7B040-1-0060 Bituminous coating raft foundation Z7B040-1-0080 250mm granular fill under ground slab Z7B040-1-0070 Backfill around raft foundation Concrete Z7B040-1-0140 Minaret Construction up to Slab level Z7B040-1-0090 Concrete blinding under grd slab Z7B040-1-0100 Concrete trench for under slab services Z7B040-1-0110 200 mm thk ground floor slab Z7B040-1-0440 Fabrication of P P ( Priority 2 - 40,244,50,265,291,90,60,,61) Z7B040-1-0120 Install P.C.C.Columns Z7B040-1-0130 Install P.C.C.Beams Z7B040-1-0210 Form / Pour Staircase Z7B040-1-0150 Erect / Fix Precast Concrete Panel Z7B040-1-0160 Erect / Fix Precast Minaret Panel Z7B040-1-0180 Installation of Roof Hollow core slab Z7B040-1-0190 Erect / Fix Mehrab Panel Z7B040-1-0200 Install Parapet Z7B040-1-0220 Roof screeding Z7B040-1-0230 Plinth Protection Slab Masonry Z7B040-1-0240 Blockworks Metal Z7B040-1-0250 PVC grating trench cover Z7B040-1-0260 Installation of handrailing Z7B040-1-0270 Installation of Brass plate Hilal Wood & Plastic Z7B040-1-0280 Compact kitchen Unit Thermal & Moisture Protection Z7B040-1-0290 Roof water proofing Z7B040-1-0300 Toilet & bathroom waterproofing Z7B040-1-0310 Finish Expansion Joint Door & Windows Z7B040-1-0320 Install Steel Frame & Door Panels Z7B040-1-0330 Install Aluminum Windows Z7B040-1-0340 Install Ironmongery ( Hardware ) Z7B040-1-0350 Install Roof Hatch Z7B040-1-0360 Install Fabric Curtains Finishes Z7B040-1-0370 Plastering of Walls Z7B040-1-0380 Plastering Ceiling Z7B040-1-0410 Internal painting preliminary coats Z7B040-1-0420 Floor terrazzo tiles & skirting Z7B040-1-0480 Install Aluminum strip Suspended ceiling Z7B040-1-0390 Floor screeding for carpet Z7B040-1-0400 Trowelled concrete w/ hardener Z7B040-1-0430 Floor terrazzo tiles - External Z7B040-1-0460 Glazed ceramic wall tiles & skirting Z7B040-1-0474 Mosaic Tiles Mehrab Z7B040-1-0450 Terrazzo treads & risers ( stair finish ) Z7B040-1-0490 Final coat of paint Z7B040-1-0470 Unglazed ceramic floor tiles Z7B040-1-0476 Mosaic Tiles Toilets Z7B040-1-0500 Install Carpet Specialties Z7B040-1-0510 Install W.C Door Z7B040-1-0520 Install Toilet & Bathroom accessories Mechanical Z7B040-1-0530 Install Soil & Vent pipe work Z7B040-1-0540 Install Cold Water Pipework & Valves Z7B040-1-0590 Install Duct work Z7B040-1-0550 Install Hot Water Pipework & Valves Z7B040-1-0600 Install volume Dampers Z7B040-1-0560 Install Sundrise & Valve Z7B040-1-0570 Install Electric water heater Z7B040-1-0610 Install Fan coil unit Z7B040-1-0620 Install Cooled Condensing unit Z7B040-1-0630 Install Sand trap louvers Z7B040-1-0640 Install Exhaust fan Z7B040-1-0650 Install wall Air Conditioning unit Z7B040-1-0580 Install Sanitary fittings Z7B040-1-0660 Install Fire Protection equimpent Electrical Z7B040-1-0670 Install Conduiting & boxes Z7B040-1-0680 Install Cabels and Wires Z7B040-1-0690 Install/Terminate Wiring Devices & Disconnect Switches Z7B040-1-0700 Install/Terminate Panelboards Z7B040-1-0710 Install Lighting Fixtures Z7B040-1-0720 Install Fire Alarm System Z7B040-1-0750 Install Grounding System Z7B040-1-0730 Install Public Address System Z7B040-1-0740 Install Telephone System Z7B040-1-0760 Install Lightning Protection System Member for 16 years 11 months Member for 16 years 11 months Submitted by Shah. HB on Tue, 2011-11-01 17:14 Permalink Hi rrr4all Congrats Hi rrr4all Congrats Log in or register to post comments
17 years 9 monthsDear Plz find activities
Mosque ( 7-B040-1 )
Site Work
Concrete
Masonry
Metal
Wood & Plastic
Door & Windows
Finishes
Specialties
Mechanical
Electrical
16 years 11 monthsHi rrr4all Congrats
Hi rrr4all
Congrats
