Updated Program
W
warren sika 👤 Member for 13 years 5 months
Can anyone help me with my problem? I have this updated program and I want this to return to the original program which is not updated yet. If it has 15000 activities and 12000 are already on progress. Is there any short cut that will make it unupdated? I want all activities not started. Thanks.
S
sheik faizal 👤 Member for 13 years
If i have understood in this way that you need your plan as without updation ie like your baseline plan....then u can just restore your baseline to a seperate project to get your original baseline schedule....hope this helps....sorry if i hav understood it wrongly.
W
Sir Alexandre,
I had success with most of the activities but those with complete status had errors. At least now, I have few to manually edit. Probably because some have constraints. I don't know but at least few remains to be edited. Thanks Sir.
Beware that P6 can without warning change original duration values:
“Much Ado about Dates” Understanding P6 Date Information
Ron Winter, PSP and F. Burak Evrenosoglu, CCE PSP
Presented at the AACEi Annual Conference
July 1, 2009
If you change the planned start date manually start date will change but early start will not change. Schedule CPM calculation will overwrite the user input with the calculated early start date. There is no warning to the user that their input will be overwritten.
The user can input a planned finish to overwrite the calculated planned finish. This change will also automatically change the original duration of the activity and there is no warning to the user.
Therefore un-statusing might be unreliable. Always the best way is to keep a copy of the original un-statused file. Unfortunately it is not always under our control and sometimes we must work with whatever files we are supplied.
Also it might be possible that other un-wanted values are left if you do not delete them, actual costs/expenses might be one of the values you shall also clear. I  am not sure it is still a BUG but as I recall in older versions of P6 you could not un-mark a started an activity if it have actual resource units but it would allow you to un-mark it with actual expenses.
I would advise that when you finish your baseline create a user defined field to record the approved baseline original durations and keep it in this ways always available without need to compare with other files.
I believe a global change can go as far as clearing all actual values including activities with 0 original duration/milestones with actual expenses/costs but will not always be able to recover initial original duration.
Alexandre Faulx-Briole 👤 Member for 23 years 4 months
Warren,
If
Original Duration is not equal to 0
And Activity % Complete is not equal to 0
Then
Units % Complete equals 0
And Duration % Complete equals 0
And Physical % Complete equals 0
And Activity Status equals Not Started
Hope this will help you,
Alexandre
W
Thanks Mr. Alexandre. How to set these parameters? I could not find them in the list. Could you please expound a bit? Thanks.
Warren
Warren,
if you want to set all activities to NOT STARTED, you may use a Global Change:
1. change all Actual Units to 0 (zero)
2. change all % complete to 0
3. change all Actual Start to Null
Alexandre
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
