Licensing in P6 V7
David Andreotti
User offline. Last seen 8 years 7 weeks ago. Offline
We recently purchased 20 licenses from an authorized rep. and received only one set of discs.
 We started loading the cd on several computers. My question is: will the CD continue to load after the 20th install? We're not trying to use more than we bought - it's possible that we may load it on someone's machine and they may never use it so we would want to be able to install it on another machine. Will the CD know how many times it's been used?
Simon Willson
User offline. Last seen 2 years 37 weeks ago. Offline
Hi David,
If you are setting up a client / server network, you will be able to install the application on as many machines as you like.  Your user community are managed with each user being allocated a license by the DBA.  The server will limit the number of active users to the number of licenses you have purchased.  You can have more users in your pool but can only allocate the number of licenses you have purchased.
Hope this helps.
David Kelly
User offline. Last seen 1 year 38 weeks ago. Offline
Oracle's licensing conditions are very easy to follow. It is YOUR responsibility not to exceed the licenece count you have bought, someone in your organisation has agreed and signed for that.
The CD will install for ever.
