Weighting Factor for computing % complete
Lalith Rathnayake
User offline. Last seen 14 years 47 weeks ago. Offline
Dear Planners,
I am using P3 (ver.3.1)
- My program is resource loaded for Labor, Material and equipments with Cost Category values L, M, & E respectively.
- I want to use Manhours ( i.e. only labor resources) as weighting factor when computing % complete.
- When I select resource units as weighting factor (Tools --Option -- summerization -- resource units) P3 uses all resources regardless of the unit.
- How can I use only Labor resources as weighting factor for computing % complete
- Is it not advisable to load all resource categories to the schedule in this case ?
Please advice. Thank you in advance
Lalith
Lalith Rathnayake
Dear Thabeer,
Can you explain further ?
As I undrstood, even if you apply a filter P3 still sum up all resources (regardless of their unit) to compute budgeted quantity.
What I need is to get only the sum of manhours in the Budgeted quantity field.
Do i need to remove the other resource assignments (i.e. Material and Equipments) to achieve this ?
Please advice.
Lalith
TABEEB UR RAHMAN
User offline. Last seen 11 years 28 weeks ago. Offline
define a filter, cnditional to manpower
