P6 Primavera V16.2
7 replies [Last post]
Robert Corran
User offline. Last seen 1 year 23 weeks ago. Offline
How can you make the bars on the Ghant Chart Deeper (More Width) I can get the rows in the columns bigger but not the bars on the Ghant Chart, surely this can be done for large presentations?
Tahir
is it a ms sql database
give me your email adress and I will email instructions
1) Backup your P6 database
a) Log as SA into your Servername in SQL Server Management Studio
b) Expand database folder
c) Select your database --> Right-click on your database --> Tasks --> Backup
d) Choose your database, backup type, backup component and destination in General page
e) Click OK
2) Add the users manually in your new SQL Server
a) Expand Security Folder --> Right-click on Logins folder --> New Login
b) Add a new user pubuser in General page
c) Choose SQL Server Authentication
d) Type and confirm a password for pubuser
e) Uncheck Enforce password policy
f) Uncheck Enforce password expiration
g) Uncheck User must change password at next login
h) Click OK
i) Expand Security Folder --> Right-click on Logins folder --> New Login
j) Add a new user privuser in General page
k) Choose SQL Server Authentication
l) Type and confirm a password for privuser
m) Uncheck Enforce password policy
n) Uncheck Enforce password expiration
o) Uncheck User must change password at next login
p) Click OK
3) Restore your P6 database in your new SQL Server
b) Right-click on databases folder --> Restore a Database
c) Type the name of the database that you want to import in textbox To Database
d) Select From device --> Click on ellipsis button --> Add --> Browse your backup file
e) Check Restore checkbox of your backup.
4) As SA in SQL Server Management Studio, run sync script for all users
a) Run the following queries to resync the public (ex: pubuser) and privileged users (ex: privuser):
exec sp_change_users_login 'Update_One','pubuser','pubuser'
exec sp_change_users_login 'Update_One','privuser','privuser'
Tahir Nizam
User offline. Last seen 4 years 5 weeks ago. Offline
Good day All,
I want to transfer P6 database from one laptop to another new laptop, both are standalone installations. Exporting xer would take time and effort in recreating the WBS & OBS structures alongwith other settings.  Its SQL db
Any Idea ?
Robert Corran
Thank you I will take a look
User offline. Last seen 1 year 2 weeks ago. Offline
Robert, Primavera bar styles are essentially thin or thinner. It doesn't have much flexibility in presentation. I've actually used the product that I've developed Turbo-Chart to be abel to produce Gantt style charts from P6 data, and you can effectively set bars to be as thick as you like. It does require some creativity and discipline in applying codes/UDF values into P6 however, its explained here:  https://www.turbo-chart.com/turbo-chart-gantt-charts/
right click in the bar area and select bars
got to the Bar Style and select the widest bar
Robert Corran
Surely there must be a way?
Zhang Haixiang
User offline. Last seen 3 years 27 weeks ago. Offline
I think it is not possible to set bar height in P6.
the workaround is to use 2 bars for each activity
