Hierarchical coding structure
Kevin Rayner
User offline. Last seen 2 years 38 weeks ago. Offline
I have set up a hierarchical project code so I can group geographically rather tahn use the cost driven WBS. However when I pull up the project code as a column I can't populate it.
When I select the blank field I expect to be abe to see the structure, as with the wbs but it is blank. All filters are off.
What am I doing wrong?
User offline. Last seen 4 weeks 20 hours ago. Offline
its hidden until after the first tiem that you use it. If you do not see when you click in the activity code in the column then
click in the upside down triangle that says Display Cirrent Project Valve and select Filter By All Values
Kevin Rayner
My fault, it should have been an activity code not a project code.
